Carver 3851-0 Hydraulic Press
The bench top easy-to-operate press allows creation of the highest quality pellets. Manual, self-contained, press allows up to 12-ton clamping force unit with 4 in. (10.2cm) dia. platen.
Technical details:
- Work area: 15.2 x15.2 cm (6 x 6 in)
- integral safety shield
- Dual-scale gauge calibrated in metric tons and pounds
- Adaptable for use in
- pressing oils,
- separating liquids from solids,
- filtering, plastic molding,
- compression and crush testing
Evacuable die sets:
These sets are constructed to produce uniform pellets of solid samples and are compatible with hydraulic presses.
Available sizes:
- 10mm (3 units)
- 13mm (2 units)
The PIKE Technologies Hand Press
This is compact unit that easily fit trough small antichamber of the glovebox. It is equipped with a platen position dial for adjustment of the force applied to the die for reproducible sample preparation. Compatible with small die sets.
Available sizes:
- 7 mm (2 units)
- 3 mm (1 unit)
